96 cavalier passlock bypass wire colors
billy1234
Member - Posts: 12
Posted: January 06, 2007 at 3:51 PM / IP Logged
I am going to just add a resistor for a permanent bypass to my 96 Cavalier Passlock system.
In my book it shows 3 wires going to the 'passlock lock cylinder'
its shows MRD(+) is white, MRD(-) is black, MRD input is yellow
the white is 'battery', black goes to ground and one side of resistor, yellow is the other side of the resistor.
My problem is that all 3 of my wires from cyclinder to instrument cluster are black........except one of the wires has a white stripe. Would that be the white wire  (MRD(+))?
I was going to cut the other 2 and measure resistance to see if I am correct, just thought I might as well check with you guys first.
KarTuneMan
Platinum - Posts: 7,056
Posted: January 06, 2007 at 4:40 PM / IP Logged
https://www.the12volt.com/installbay/file.asp?ID=237
The wires you need exit from the pass. side of the steering column.
billy1234
Member - Posts: 12
Posted: January 06, 2007 at 5:30 PM / IP Logged
ya. I guessed at it and it works. I did not add resistor, just cut the reference wire while the car was running and it all works now. Only thing is my theft light is on. will add a resistor one day to get rid of that.
Clay
