Door solenoids?
badtexasz28
Member - Posts: 23
Posted: January 08, 2007 at 5:13 PM / IP Logged
I am pretty sure I am in the right forum...if not mods, feel free to move it.
I have autoloc's 75lb pull solenoids in all 4drs of my dodge ram and i am having trouble with them, the inner rod which is held together with e-clips, keeps pulling through those said e-clips. Is there another solenoid that maybe has a threaded end or some other sort of clip to hold it together?
I was born with nothing and I still have most of it left.
Hymer
Silver - Posts: 695
Posted: January 08, 2007 at 5:37 PM / IP Logged
Dump the E clips and weld in some tubeing so the rod can't pull off..
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
badtexasz28
Member - Posts: 23
Posted: January 08, 2007 at 11:49 PM / IP Logged
i would still like to be able to rebuild it if need be....maybe i can just thread the rod and put a nut or two on it.
Hymer
Silver - Posts: 695
Posted: January 09, 2007 at 12:02 AM / IP Logged
How are you pulling with the solenoid. sol. pulling the rod or a direct pull to the latch release? I know it's a pain, but cutting the inner door a bit and fabing some brackets, then useaircraft cable to pull the release lever on the latch gives ya a pretty fail safe door popper. Mabey I'm just not following your method...
badtexasz28
Member - Posts: 23
Posted: January 09, 2007 at 8:47 AM / IP Logged
It is pulling the latch, the solenoid is mounted on the lower portion of the door and guide up to the latch for a direct 90 degree pull on the latch assembly itself (using sheathed aircract cable).
Hymer
Silver - Posts: 695
Posted: January 09, 2007 at 8:52 AM / IP Logged
Ok that sounds like it's right, what rod is it pulling out? afterre reading your post, I am assuming it is the solenoind that you are having problems with not the door mechanism... correct?
badtexasz28
Member - Posts: 23
Posted: January 09, 2007 at 8:25 PM / IP Logged
correct, it is the solenoid. the inner piston/rod thing that runs through the center of the electromagnet,
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
