Any way to hook up RS to open Garage Door
mbaudio06
Copper - Posts: 60
Posted: January 15, 2007 at 3:41 PM / IP Logged
If there is a way please recommend a certain RS with this option. Or maybe any RS with some sort of Aux output..
Hymer
Silver - Posts: 695
Posted: January 15, 2007 at 3:46 PM / IP Logged
You could crack your remote open for the door opener and run a aux output to pulse a relay to close the contacs on the switch in the opener. the remote would need to be permanantly in the vehicle... should be pretty simple....
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
profuse007
Gold - Posts: 2,015
Posted: January 15, 2007 at 5:23 PM / IP Logged
^thats prolly the cheapest way to do it. else, you can buy a module from clifford, audiovox, or DEI. check eeebayDOTcom
Houston,TX
Tuesday, December 2, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
