530T wiring 2005 F-150
gtchida
Copper - Posts: 89
Posted: January 16, 2007 at 11:31 PM / IP Logged
Hello all, I have a 2005 F-150 and I am trying to install a 530T for the front windows but I am having difficulty getting the wiring correct. Usually, once I have tapped into the motor wires I will check the PW switch to be sure they operate correctly before I make the final connections (power, ground, etc.) on the module and on this one, I get nothing. I accessed the wires for the driver door in the door and the passenger wires in the kick panel. Here is the diagram for the windows that I have followed:
LF Window up/dntan/lt. blue - WHITE/ black A driver window switch in door
RF Window up/dntan/lt. blue - WHITE/ yellow A driver kick, door harness
LR Window up/dnyellow/lt. blue - gray/orange A driver kick, door harness
RR Window up/dnRED / black - yellow/black A driver kick, door harness
I have read the manual over and over, checked the wiring connections over and over, but I still cannot figure it out. I know I must be overlooking something simple. I appreciate any help/direction.
Gary
gtchida
Copper - Posts: 89
Posted: January 17, 2007 at 4:41 PM / IP Logged
Can anyone help?
KarTuneMan
Platinum - Posts: 7,056
Posted: January 17, 2007 at 7:17 PM / IP Logged
530T wiring 2005 F-150 -- posted image.
Is this how you are attempting to wire the windows?
gtchida
Copper - Posts: 89
Posted: January 17, 2007 at 10:01 PM / IP Logged
Yes, I followed type "A" windows per the 530T instructions...
Gary
KarTuneMan
Posted: January 17, 2007 at 10:49 PM / IP Logged
I did not know that the power window wires were in the kick panal.....are you very certain of this?
gtchida
Copper - Posts: 89
Posted: January 18, 2007 at 8:19 AM / IP Logged
They run along the threshold of the drivers door. I used a DMM to test.
Gary
cntrylvr79
Silver - Posts: 582
Posted: January 18, 2007 at 8:38 AM / IP Logged
You know the 530t HAS to have power and ground in order for the windows to work at all once you cut the motor wires?
Cause I'm So white and nerdy...
First Class Certi-fried installer
gtchida
Copper - Posts: 89
Posted: January 18, 2007 at 5:52 PM / IP Logged
I did not know that, thanks for the help...I was just assuming because the 529 would work without power/ground, the 530 would be the same.
Gary
cntrylvr79
Silver - Posts: 582
Posted: January 18, 2007 at 10:07 PM / IP Logged
Yeah it's not.  ONce you have that installed, the 530t takes total control over the windows.  The switches just become triggers for the 530 since they're no longer connected to the motors.  That's part of the reason why the 530t gives you fully auto control of the windows.
gtchida
Copper - Posts: 89
Posted: January 18, 2007 at 10:52 PM / IP Logged
Thanks again, that was a big DUH on my part.
Gary
