converting polarity 2nd starter vs status
ihkili18
Copper - Posts: 108
Posted: January 27, 2007 at 6:24 PM / IP Logged
Hey guys I am about to install a ultrastart into a honda accord manual. The ultrastart only has a positive 2nd starter and a - status output for the transponder bypass. To bypass my clutch would it be smarter to convert the signal of the 2nd starter to negative using a relay or should i use the status output which is neg to do both bypassing the clutch and triggering the transp bypass? thanx
KarTuneMan
Platinum - Posts: 7,056
Posted: January 27, 2007 at 7:29 PM / IP Logged
Whats the exact part # of the unit your installing?   "ultrastart" ?
Also...what year car?
Typically the "status output" or ground while running,  triggers BEFORE anything in the ignition harness portion of your remote start. That might not work for your clutch bypass......
ihkili18
Copper - Posts: 108
Posted: January 27, 2007 at 9:16 PM / IP Logged
2005 v6 ex coupe 6 speed  (and while your at it give me the same info for a 05 rsx type s )      and im installing a ultrastart 4266m. thanx in advance
