1992 240sx se remote start trouble
grizeg
Member - Posts: 6
Posted: February 01, 2007 at 5:12 PM / IP Logged
I'm installing a Viper alarm system into a 1992 240sx SE, when i hit the remote start button the ignition cuts on, and the lights on the dash light up, my seat belts also go back, but the car does not start. i have read in areas that this car has 2 ignitions i can not find the second, any ideas as to where its located or, what i might be doing wrong?
rudydapimp
Copper - Posts: 390
Posted: February 01, 2007 at 5:31 PM / IP Logged
you have a second starter wire.  prob can use 2nd ignition output from R/S to power it as well.  No second ignition that Ive seen in that car. it is BLACK / YELLOW.
grizeg
Member - Posts: 6
Posted: February 02, 2007 at 5:31 PM / IP Logged
do you know which wire goes to which?
The wires coming off the key cylinder are this
BLACK/ green
BLACK / YELLOW
BLACK/ white
WHITE/ red
blue
My remote start harness is this
purple - (+) starter output to starter (starter side)
green - starter input from ignition (key side)
red - (+) high current 12v input
orange - (+) output to accessory curcuit
pink - (+) output to primary ignition circuit
pink/white - (+) output to second ignition circuit
RED / white - (+) high current 12v input
grizeg
Member - Posts: 6
Posted: February 03, 2007 at 11:29 AM / IP Logged
ok, also i have tried the single wire system, and it is unlocking, but not locking... what is going on with that?
https://www.the12volt.com/doorlocks/page2.asp#n1
Thursday, February 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
