is keysense required on a 04 rsx
csnut18
Copper - Posts: 196
Posted: February 02, 2007 at 8:55 PM / IP Logged
Hi everybody, just wondering if keysense is required on a 04 rsx. I am installing a new compustar pro on this car. I was thinking that wiring up the factory disarm and arm should be enough. Am I correct. Thank you
KarTuneMan
Platinum - Posts: 7,056
Posted: February 02, 2007 at 9:42 PM / IP Logged
 LOCK WHITE/ blue/2 silver dots On 16-pin BLUE plug above driver's kick   -
 UNLOCK WHITE/ GREEN/ 2 silver dots On 16-pin BLUE plug above driver's kick   -
 FACTORY ARM WHITE/ RED / 2 silver dots On 16-pin BLUE plug above driver's kick   -
 These wires can also be found on the 20-pin plug at the factory alarm. See the photo.
 FACTORY DISARM WHITE/ 2 silver dots On 16-pin BLUE plug above driver's kick   -
JWorm
Platinum - Posts: 2,208
Posted: February 02, 2007 at 9:59 PM / IP Logged
Key sense is not needed.
csnut18
Copper - Posts: 196
Posted: February 02, 2007 at 10:11 PM / IP Logged
Thanks for the responses. Now a similiar question, would sending a pulse to the keysense disarm the factory alarm? I think it does cause putting the key in the ignition without turning it seems to disarm the factory alarm. so correct me if I am wrong.
JWorm
Posted: February 02, 2007 at 11:03 PM / IP Logged
I don't think it would, but I can test it tomorrow on my RSX and let you know then.
Why wouldn't you just connect to the arm and disarm wires listed above?
csnut18
Copper - Posts: 196
Posted: February 02, 2007 at 11:21 PM / IP Logged
I will do that but I wanted to know if in general if doing the keysense would disarm the factory system. The reason i am asking is in some cars like the new accords the factory disarm requires going into the door so to save time i was wondering if the keysense would do it. i think it does cause in the accords putting the key in disarms everything
