06 suzuki xl 7 wiring?
tintman97
Copper - Posts: 113
Posted: February 05, 2007 at 12:10 PM / IP Logged
Does anyone have a diagram for this.  IT is not the same as 2005.   no even close this is a whole new monster.  I belive this has a transponder also with the way it has the ring around the igniton looks like a fords transponer module.
Snapper
tintman97
Copper - Posts: 113
Posted: February 05, 2007 at 4:24 PM / IP Logged
I belive this is like a equinox any help?
Snapper
mikvot
Gold - Posts: 1,043
Posted: February 05, 2007 at 6:29 PM / IP Logged
12volts
      WHITE/ green (60A)
      ignition harness
Starter      BLACK/ red       +       ignition harness
Second Starter      N/A
Ignition      BLACK/ blue       +       ignition harness
Second Ignition      N/A
Third Ignition      N/A
Accessory      yellow/black       +       ignition harness
Second Accessory      blue       +       ignition harness
Keysense      blue/red       +       ign harn or BCM, 16 pin plug, pin 13
Power Lock      pink/black       -       BCM, 12 pin plug, pin 1
Power Unlock      pink/green       -       BCM, 12 pin plug, pin 7
Lock Motor      blue       5wi      BCM, 22 pin plug, pin 12
Unlock Motor      blue/white       5wi      BCM, 22 pin plug, pin 2
Parking Lights+      RED / yellow       +       BCM, 22 pin plug, pin 22
Parking Lights-      RED / blue       -       BCM, 22 pin plug, pin 9
Hazards      yellow/red       -       BCM, 22 pin plug, pin 17
Turn Signal(L)      GREEN/ red       +       turn signal relay, left of column
Turn Signal(R)      GREEN/ YELLOW       +       turn signal relay, left of column
Reverse Light      red       +       driver kick, harness to rear
Door Trigger      BLACK/ red       -       BCM, 16 pin plug, pin 16
Dome Supervision      BLACK/ red       -       BCM, 22 pin plug, pin 14
Trunk/Hatch Pin      common with door trigger wire
Hood Pin      N/A
Trunk/Hatch Release      N/A
Power Sliding Door      N/A
Factory Alarm Arm      pink       -       BCM, 12 pin plug, pin 2
Factory Alarm Disarm      pink/blue       -       BCM, 12 pin plug, pin 8
Disarm No Unlock      see factory alarm disarm
Tachometer      brown       ac       cluster or ECM, 35 pin plug, pin 6
Wait to start      N/A
Brake Wire      GREEN / WHITE       +       brake pedal switch
Parking Brake      RED / black       -       BCM, 16 pin plug, pin 5
Horn Trigger      blue/green       -       BCM, 22 pin plug, pin 4
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
According to directechs,no bypass is needed
tintman97
Copper - Posts: 113
Posted: February 05, 2007 at 7:22 PM / IP Logged
OK directtech is WRONG not even close to the 05.  There is no start wire at all  same as equinox .   only 2 real ignition wires   one is solid ignition the other is accessory and it powers up then dead then on solid.   Just like a Equinox but the guides do not match all tested with  a DMM all theses new stupid sytems are retarded stick with what works
Snapper
tintman97
Copper - Posts: 113
Posted: February 06, 2007 at 10:38 AM / IP Logged
need the diagram  for 2007 XL7 apparently
Snapper
