omega pass 4 ok for '06 jeep g.cherokee?
peterubers
Silver - Posts: 706
Posted: February 19, 2007 at 4:48 PM / IP Logged
Customer doesn't mind losing a key -- is this bypass acceptable?  It's the standard ribbon around the key-head .. and ring around the key barrel...
The search function is your friend.
splaudio
Copper - Posts: 237
Posted: February 19, 2007 at 6:29 PM / IP Logged
yes that will work fine for the transponder. but i would get a databus bypass that dose the door locks too...
peterubers
Silver - Posts: 706
Posted: February 19, 2007 at 9:39 PM / IP Logged
I was gunna tap into the lock/unlock common wire in the Cherokee with a ground signal via 300 and 100 ohm resistors -- can I do this?  then I don't have to implement the databus bypass for the doorlocks?
The r/s has a (-) signal for lock and unlock -- can i just use resistors?
thanks for the reply
splaudio
Copper - Posts: 237
Posted: February 20, 2007 at 7:37 PM / IP Logged
yes u can
peterubers
Silver - Posts: 706
Posted: February 20, 2007 at 9:42 PM / IP Logged
thanks guys
