03 ford windstar door trigger proble
newinstaller
Copper - Posts: 160
Posted: February 26, 2007 at 8:39 PM / IP Logged
03 ford Windstar door Trigger Problems
anyone know about the alarm going off 45 min after you arm the car? How do I solve this with a relay?
cutter1122
Copper - Posts: 103
Posted: February 26, 2007 at 9:07 PM / IP Logged
03 ford windstar door trigger proble -- posted image.
newinstaller
Copper - Posts: 160
Posted: February 26, 2007 at 9:15 PM / IP Logged
I know there is a way to do this with just adding a relay
Hymer
Silver - Posts: 695
Posted: February 27, 2007 at 10:38 AM / IP Logged
This may help ya...   get a relay 86 to +12v on dome light wire, 85 to (-) side dome wire, 87 to ground, 87a through a 500 ohm resistor to 12v, 30 to (-) door pin input wire.    Aparently these things fall asleep and then the dome light wires will switch polarity..
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
