compustar alarm went crazy
asianjack
Member - Posts: 30
Posted: March 11, 2007 at 12:34 PM / IP Logged
i have a compustar and its been working fine for about 5 months now, but yesterday i was taking a little road trip and when we were getting into the car the alarm went off. i tried turning it off but the horn kept going off. i disconnected the entire alarm box and the horn still went off. im guessing it was the factory alarm. it stopped after 10 mins then came back on. so i just pulled the horn fuses and anti theft fuse, it stopped but my headlights kept flashing so i had to disconnect my battery when  i was parked.
what can i look for to solve this problem.
Platinum - Posts: 12,488
Posted: March 11, 2007 at 5:52 PM / IP Logged
What make, model & year vehicle is it ? If you diconnected the entire alarm CPU and the horn kept going off, then it's not a Compustar problem, rather an installer error where they did not tie into the OEM ALARM DISARM wire. There could have been several reasons why the OEM alarm has been dormant but most likely is that it can only be ARMED via the OEM remote or by locking the door via the key cylinder in the door.
asianjack
Member - Posts: 30
Posted: March 11, 2007 at 6:34 PM / IP Logged
oh yeah sorry about that its a 1998 eclipse.
i installed the alarm and it use to go off randomly but my instructor fixed the problem.
Posted: March 11, 2007 at 10:26 PM / IP Logged
You can arm the OEM system via the key cylinder in the door. To fix this problem, you must use the OEM disarm (-) output from the remote start and wire it to the GREEN / WHITE wire in the driver's kick panel or in the driver's door harness.
asianjack
Member - Posts: 30
Posted: March 12, 2007 at 1:25 AM / IP Logged
oh yeah thats already been done. i think i had to use a diode for that, i cant remember. but i remember having to use about 5 diodes for the door lock and unlock. ill try to arm the oem system tomorrow. thanks
