99 jeep window module
harrisell1
Copper - Posts: 93
Posted: March 11, 2007 at 12:34 PM / IP Logged
I have autopage 860 and connecting two window modules ac-78 (4 windows up and down). Everything works fine except the ground when armed wire becomes active when the ignition is turned off which roles up the window when I want them to roll up when the alarm arms.  Not sure what's going on. (99 jeep chrokee)
electronics
KarTuneMan
Platinum - Posts: 7,056
Posted: March 11, 2007 at 2:38 PM / IP Logged
Are you sure you have the ground when armed....it doesn't sound like it. That trigger should only work when you manually arm. Is the unit programmed for "passive" arm, or lock?
harrisell1
Copper - Posts: 93
Posted: March 11, 2007 at 7:19 PM / IP Logged
yes, it programmed for passive locking and I connected to the orange wire on the 860.  Maybe I will try the ORANGE / white see if those two wires were put in the harness in reverse at Autopage company.
electronics
harrisell1
Copper - Posts: 93
Posted: March 23, 2007 at 11:41 PM / IP Logged
I figured it out, I diode isolated the ground when armed. The ignition was feeding back into the relay giving the modules a signal.  Everythings fine, starter disabe, windows, and hyper blue light, all activate when alarm arms. Thanks
electronics
Friday, January 30, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
