06 impala remote start
voluster
Member - Posts: 20
Posted: April 11, 2007 at 11:08 AM / IP Logged
Has anyone done one of these .
I have DEI's tech sheet and astroflex tech sheet and one says one thing and one says something totally different.
going by Dei  they are saying use a 556u and it's pretty staight forward car that starts once the ing lights up and the acc drops off.
but now Astro says it's like a colorado  or hummer h3 type wiring .
I'm gonna be doing this car on the side  guy has 2 of them . just haven't seen one of these in the shop yet.
This is gonna be on my time so I would like to make sure I have my info correct before I dive right in
Thanks for any input
Phil
Hymer
Silver - Posts: 695
Posted: April 11, 2007 at 11:27 AM / IP Logged
XK 01 [door locks, don't really need it] ] and XK06 hybrid passkey bypass that way ya don't have to bury the key, other than that the car is pretty easy.
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
voluster
Member - Posts: 20
Posted: April 11, 2007 at 3:05 PM / IP Logged
I'm not worried about burying a key   they have 3 for each car
i'm just wondering whos tech sheet I should follow.
is it one of them cars that see ing and acc then drop off the cars knows to start or is it when i have to cut this measure the resistence against another wire type of deal.
I'm just trying to make sure I have what I need before I drive to the job get into it and find out I need something that I don't have access to on the weekend
Hymer
Silver - Posts: 695
Posted: April 11, 2007 at 3:36 PM / IP Logged
I use Astros chart. If you have he diagram from them it explains it all. Whan the ign goes hot it breaks connection to the keysense/starter wire and use another relay programed to energize when the starter wire goes hot [from the remote starter] to send 1.3k to the reference wire. If you need the pinout just say the word...
voluster
Member - Posts: 20
Posted: April 12, 2007 at 8:23 AM / IP Logged
Sure if you could fire me that print out that would be great .
Voluster@comcast.net
thanks for your help
