alarm in a 2003 xterra
Prophit
Copper - Posts: 79
Posted: May 19, 2007 at 5:20 PM / IP Logged
Im installing an ASIANWOLF FM 2009 in a 2003 nissan xterra. I have a factory alarm installed currently. I Just wanted to know if there where any special instructions for this install? I did find the instructions from this site,
NISSAN / XTERRA / 2003 / Remote Start
12voltsgreenignition harness
Starter BLACK / YELLOWignition harness
Second Starter GREEN/ YELLOWignition harness
IgnitionBLACK/ whiteignition harness
Second Ignition
Third Ignition
AccessoryRED / yellow ignition harness
Second Accessory WHITE/ blue ignition harness
Notes: NOT required for remote start.
Keysense
Power Lock yellow   -   SECU
Notes: Meter these wires while turning the key in either door key cylinder.
The SECU (Smart Entrance Control Unit) is to the right of the steering column.
Power Unlock yellow/redSECU
Notes: Meter these wires while turning the key in either door key cylinder. Unlock requires a double pulse.
Lock Motor blue  blue 5wi SECU
Notes: The SECU (Smart Entrance Control Unit) is to the right of the steering column.
Unlock Motor GREEN / WHITE 5wiSECU
Parking Lightsblue/red steering column
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger     -
Vehicles with power door locks use GREEN/ red for the driver door, GREEN/ black for the front passenger door, and RED / black for the rear doors. All found at the SECU, use all three wires and diode isolate each.
Dome Supervision
Trunk/Hatch Pin
Hood PinBLACK/ pinkSECU
Trunk/Hatch Release
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock single pulse on unlock wire
Tachometer pink/blue or blackinstrument cluster or ECM
Notes: The ECM (Engine Control Module) is located below the heater box to the right of the accelerator pedal, behind trim panel. The tach is in the top row, 3rd pin left of center of the plug.
Wait to start N/A
Brake WireBROWN / redbrake pedal switch
Parking Brake
Horn Trigger ltGREEN/ red or brown steering column
Im doing this install on monday and wanted to get everything ready and setup before hand. Thanks for the help
mikvot
Gold - Posts: 1,043
Posted: May 19, 2007 at 7:12 PM / IP Logged
Nope, nothing special if its just an alarm..............slaaaammmerrrrr
12volts
Starter
Second Starter
Ignition
Second Ignition
Third Ignition
Accessory
Second Accessory
Keysense
Power Lock
Power Unlock
Lock Motor
Unlock Motor
Parking Lights+
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger
Dome Supervision
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Disarm No Unlock
Tachometer
Wait to start
Brake Wire
Parking Brake
Horn Trigger
NISSAN, XTERRA, 2003, Door Trigger
On vehicles without power door locks use RED / black at any door pin switch or also found in the driver A pillar. Vehicles with power door locks use GREEN/ red for the driver door, GREEN/ black for the front passenger door, and RED / black for the rear doors. All found at the SECU, use all three wires and diode isolate each.
Prophit
Copper - Posts: 79
Posted: May 22, 2007 at 4:29 PM / IP Logged
Thank alot for those directions. Im a little rusty. Im having problems with the door locks. Could someone show me a diagram that would work for my application. I believe i have a 2 zone reversed polarity. But i could be wrong. Am i going to need relays? I have a couple i believe to be 5wi modules. Could i use those? I have almost the rest done. Just need to figure out window modules. I will post about that later. Thanks. I have pictures of instructions for my alarm if needed.
