alarm, which wires should i be chasing?
stinkyfatpig
Member - Posts: 12
Posted: May 28, 2007 at 10:44 AM / IP Logged
my alarm isng working and im wondering which wires i should be chasing.  I didnt install it so its look like a huge messs of wires to me.  So i got the wiring diagram  im assuming i just need to worry about the actual power wires right?  li shouldnt have to worry about the locks and the LEDS etc?  any tips would be very helpfull.
audioman2007
Copper - Posts: 580
Posted: May 28, 2007 at 10:49 AM / IP Logged
ok first thing everyone needs to know before we can help you is:  alarm make and module and what vehicle was it installed into?
stinkyfatpig
Member - Posts: 12
Posted: May 28, 2007 at 12:24 PM / IP Logged
Good call i forgot about that
Ungo
MS2004 03070004s   in a 89 toyota 4x4   with locks
swamprat323
Gold - Posts: 1,335
Posted: May 28, 2007 at 1:12 PM / IP Logged
what is not working give much info as you can.
stinkyfatpig
Member - Posts: 12
Posted: May 28, 2007 at 1:52 PM / IP Logged
Basicly it doesnt do anything. I cant get it to arm.. or do anything for that matter.  the LEDs are disconnected though.  basicly i bought this truck with the alarm. and it was working and when i bought it the guy took his stereo out and after that it stopped working.. the only thing that he said he did to the alarm was take out the leds.. and i heard that even if there out that shouldnt effect the function of the actuall alarm. so i figure it may have just been a lose wire.  this truck has had alot of other wiring so there is a bunch of "extra" wires around so its hard to figure it out for sure.
I have checked the real easy stuff like fuses.. and thats not the issue..
but i havent really touched the wiring.. i looked at it and theres no harnesses disconnected or anything..
rudydapimp
Copper - Posts: 390
Posted: May 28, 2007 at 9:14 PM / IP Logged
I would check the power leads, and the ground leads for sure. if you have power and ground hooked up correctly, the alarm brain will at least click when you push buttons on it( just like it would when doors are unlocked or trunk release is activated.) after that, check ignition lead, parking light output and so on. but power and ground are the two critical items that must be there, esp the ground wire.
stinkyfatpig
Member - Posts: 12
Posted: June 01, 2007 at 3:02 PM / IP Logged
so i went and took alook and i am getting power and switched power to it the motion sensor is blinking when i tap it.. everything seems to be working.. i just cant get it to do anything.
any other ideas?
Posted: June 03, 2007 at 7:06 AM / IP Logged
Checked out/changed batteries on remote(s)? Is antenna atached?
stinkyfatpig
Member - Posts: 12
Posted: June 03, 2007 at 11:00 PM / IP Logged
tried both remotes.. its not the remote, what does the antenna look like?  i thought the main unit was the antenna?
Posted: June 04, 2007 at 1:51 AM / IP Logged
Get hold of owner/install manual and check diagrammes!
Saturday, November 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
