twist or tape harnesses
swerks
Copper - Posts: 224
Posted: July 30, 2007 at 4:32 PM / IP Logged
just a bit of an opinion question whats better taping rs harnesses or twisting with drill.
my moneys on taping, i dont see auto manufactures twisting their harnesses. also i believe twisting puts an awful lot of undue stress on the wires and connectors
Steve Sverdahl
Swerksound Auto Electric
Red Deer Alberta
swerks
Copper - Posts: 224
Posted: July 30, 2007 at 4:33 PM / IP Logged
also i think its a lot easier to take your knife and open a taped harness rather than untwist one if troubleshooting is required
Steve Sverdahl
Red Deer Alberta
KPierson
Platinum - Posts: 3,527
Posted: July 30, 2007 at 4:40 PM / IP Logged
I do both.  I twist up wires going to the same area of the vehicle and then I tape over it.
If I had to choose one, I would go with tape just to cover the colored wires to make the install look more OEM.
I wouldn't worry too much about the stress on the wire, unless you are twisting the wires super tight!
Kevin Pierson
captainzab
Silver - Posts: 606
Posted: July 30, 2007 at 5:21 PM / IP Logged
i say tape if its under the dash.if you are just wiring things in the door, you can ziptie the wire to other factory wire. (i just leave the color exposed since a thief wouldnt take out a door panel)plus, troubleshooting is much easier.
I rarely twist wires.
Note: You Always Dont Get What You Pay For.
dswift
Copper - Posts: 396
Posted: July 30, 2007 at 5:28 PM / IP Logged
Twist and tape. Manufacture's dont twist them because installers have specific ways they prep their own harnesses for specific cars/trucks.
"dont ground out!"
swerks
Copper - Posts: 224
Posted: July 30, 2007 at 5:52 PM / IP Logged
i would say that auto makers dont twist because it makes digging wires out difficult.
i have trobleshot numerous installations where an installer twisted harnesses and it interferes with the pins making proper contactwitk the rs, so i believe extra stress is an issue
Steve Sverdahl
Red Deer Alberta
offroadzj
Gold - Posts: 2,043
Posted: August 10, 2007 at 12:41 AM / IP Logged
i do like to twist, and then tape as well. However, it is very important to hold the wires you are twisting atleat 1" from the plug so you dont have to risk damaging or pulling on the pins. Then I tape the wires so that if a thief were to look under the dash, they wouldnt have a "quick hot wire" guide to stealing the car.
Just my .02
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
KarTuneMan
Platinum - Posts: 7,056
Posted: August 10, 2007 at 1:17 AM / IP Logged
When you twist wires, specially if your cutting and using your own wire, you use more wire. The twisted wire needs more wire to cover the same distance as non-twisted. I know, I know.....it's just a few inches..... x's how many jobs? If you run your own shop, and don't work for someone else! (every inch count's twist or tape harnesses -- posted image.)
fkelsey
Copper - Posts: 94
Posted: August 10, 2007 at 10:30 AM / IP Logged
Yeah but zip ties and tape don't grow on trees eithertwist or tape harnesses -- posted image.. I do both just depends on the situation.
profuse007
Gold - Posts: 2,015
Posted: August 10, 2007 at 3:39 PM / IP Logged
When you start to do a bunch of mobile electronic installs, you'll have you cut back on efforts and supplies to adjust proficiency. This method of running wires is not a necessity; its just wasting efforts. If you start your own shop and buying supplies for your employers, everything counts, like Kartoonman said.
Houston,TX
