mercedes c320 parking lights
keysersoza
Member - Posts: 37
Posted: August 08, 2007 at 7:27 AM / IP Logged
Please help have parking lights hooked up at switch to the gray / YELLOW but lights do not flash i get 12 volts across the line when i turn on the lights manually but remote wont turn on lights for confirmation do I need to use a relay for this to work. Any help would be appreciated.
Thanks Travis
KarTuneMan
Platinum - Posts: 7,056
Posted: August 08, 2007 at 8:23 AM / IP Logged
be sure to post ALL info about your car. what year is the car?
keysersoza
Member - Posts: 37
Posted: August 08, 2007 at 8:43 AM / IP Logged
Sorry 2003
keysersoza
Member - Posts: 37
I meant to type 2001 sorry
awdeclipse
Copper - Posts: 285
Posted: August 08, 2007 at 2:41 PM / IP Logged
You get 12v on the parking light wire you tapped vehicle side, or coming out of your Alarm/RS?
Have you tried to energize the suspected parking light wire manually with a fused jumper to confirm it is the correct wire? Is the polarity selectable and set correctly on your alarm output?
enice
Silver - Posts: 857
Posted: August 08, 2007 at 7:47 PM / IP Logged
Wouldn't recommend giving it a jumper.  You can verify with a DMM when you turn on the lights you would see some type of reading.  Either 12v to 0v or 0v to 12.  You might actually have the wrong wire and therefore damaging something.  If it does turn on then you may do it but from the looks of it(not judging you) it looks like it would not be appropriate for you to use a probe.
Posted: August 11, 2007 at 11:18 AM / IP Logged
Look to the colours at each back light, also nyou might be running foul of an internal check system sniffing out resistance on these wires.
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
