hooked up alarm, pager says error
oblique
Posted: August 22, 2007 at 9:01 PM / IP Logged
I hooked up an Airwolf alarm but the pager says error. I have only hooked up the power wires(12V, IGN 1, IGN 2) and I have a starter interrupt relay hooked up. Do I have to have the door sensor hooked up for the alarm to function? What is the minimum I need to have connected.
I plan on hooking everything else up, I just wanted to see if the alarm worked before I started cutting a lot of wires.
JWorm
Platinum - Posts: 2,208
Posted: August 22, 2007 at 9:29 PM / IP Logged
You didn't mention hooking up the ground wire...that will need to be done before it works correctly. I'll also assume you hooked up the antenna.
Some units need to have the pager remote programmed to the unit before it will work. Some alarms need to have the door trigger hooked up to enter remote programming. I have not used an Airwolf alarm before, so I'm not sure if these things apply to your alarm.
Good luck.
oblique
Posted: August 22, 2007 at 11:40 PM / IP Logged
Ground wire and antenna are both hooked up. When I go to program the remote, the display says error and "d00-" I think "d00-" means "door" but I'm not sure.
