keysense wire 05 f150
electroman
Posted: October 19, 2007 at 8:35 AM / IP Logged
connected pro start ct3100 and xk04 bypass module.truck starts but only runs for 15 seconds,shuts down. all gauges work except fuel gauge. pretty sure module is programmed correctly,but still having grief any ideas would be appreciated.
KarTuneMan
Platinum - Posts: 7,056
Posted: October 19, 2007 at 9:08 AM / IP Logged
well, if it runs for a few seconds (I'd bet it's less thatn 15) it would definatly be a bypass issue.
If it can be re-programmed, do it. Some can only be programmed 1 time.
Just  wondering why the subject title is keysence?
It's blk/pink (POS)+ in the ign. harness.
electroman
Posted: October 19, 2007 at 9:18 AM / IP Logged
what needs to be connected to keysense wire?
profuse007
Gold - Posts: 2,015
Posted: October 19, 2007 at 10:30 AM / IP Logged
make sure all ign and acc is connected for all functions to be active.
nothing as long as you have disarm connected, you shouldnt be worry, assuming oem alarm exist.
Houston,TX
KarTuneMan
Posted: October 19, 2007 at 12:34 PM / IP Logged
Ahhhh, the illusive OE ford alarm, with the disarm wire that has never been seen!keysense wire 05 f150 -- posted image.
Twelvoltz
Platinum - Posts: 2,384
Posted: October 19, 2007 at 5:40 PM / IP Logged
Now that is funny! The blinking red LED must mean it has an alarm, right? keysense wire 05 f150 -- posted image.
