remote start for subaru?
subaruimpreza83
Posted: October 19, 2007 at 10:45 PM / IP Logged
Does a remote start work for a Subaru Impreza 2.5 RS. If it doesn't, what do I need?
tedmond
Gold - Posts: 4,610
Posted: October 20, 2007 at 5:42 AM / IP Logged
a rs unit should work on all cars if wired properly.
Twelvoltz
Platinum - Posts: 2,384
Posted: October 20, 2007 at 7:02 AM / IP Logged
If the car is fuel injected and automatic transmission than any remote start should work.
If your car has a manual transmission then you need to pick up a remote starter that is specifically designed for a manual transmission.
Since you do not mention the year of the car it would be impossible to know if you need anything else. The 1993 Impreza is a LOT different than the 2008.
subaruimpreza83
Posted: October 20, 2007 at 11:20 AM / IP Logged
It is a 98 impreza.  Would I need anything else?
Twelvoltz
Posted: October 20, 2007 at 3:59 PM / IP Logged
The 98 does not have a transponder (according to my sheets). You should be good to go with just the system itself.
Again, if it is a manual transmission do not put in a system designed for an automatic transmission.
