bmw 530i 2004 e60 central locking
sova
Posted: October 23, 2007 at 2:32 PM / IP Logged
Good day.
need central locking wiring diagram for this car.
thanks
Twelvoltz
Platinum - Posts: 2,384
Posted: October 23, 2007 at 3:15 PM / IP Logged
Audiovox lists:
     Power Unlock          BLACK/ WHITE          (+)          IN DRIVERS DOOR AT SWITCH
     Power Lock              BLUE/RED                  (+)        IN DRIVERS DOOR AT SWITCH
They also list this note:
THESE WIRES DONOT FUNCTION WHILE THE CAR IS RUNNING. YOU MUST ALSO CONNECT TO THE YELLOW/RED WIRE AT THE COURTESY DOORLOCK SWITCH IN THE CENTER CONSOLE. A GROUND PULSE TO THIS WIRE WILL SIMULTANEOUSLY LOCK AND UNLOCK THE DOORS
Hope it helps.
sova
Posted: October 24, 2007 at 8:10 AM / IP Logged
These wires for E39 .
E60 - seven wires in the driver’s door lock module connector.
Two wires – motor lock\unlock
One wire – door light switch
Brown – ground.
Black\yellow - ? 0V
Blue\red - ?    0V when rest , +9V when turning key to lock or unlock.
Yellow\? (don’t remember stripe) – 0V when rest, switching +10V when turning key to lock or unlock and 0V after few minutes.
Posted: October 24, 2007 at 10:51 AM / IP Logged
Sova, not the lock module, it's a plug on the switch.
kola7126
Copper - Posts: 93
Posted: October 24, 2007 at 5:26 PM / IP Logged
Adapter CAN is necessary for connection
