2007 outlander, remote start info
theronsmith
Member - Posts: 36
Posted: November 07, 2007 at 7:01 PM / IP Logged
Can anyone out there help me out with remote start info?
chevy II
Twelvoltz
Platinum - Posts: 2,384
Posted: November 07, 2007 at 7:55 PM / IP Logged
Audiovox lists:
          #513740: 2007 MITSUBISHI OUTLANDER 4DR SUV WITH 3.0L ENGINE AND 6-SPEAKER AUDIO SYSTEM
     Audio/Mobile Video
     WIRE          COLOR          POLARITY          LOCATION
     Battery          RED / WHITE          (+)          RADIO HARNESS
     Accesory          YELLOW          (+)          RADIO HARNESS
     Ground          BLACK          (-)          RADIO HARNESS
     Illumination          GREEN / WHITE          (+)          RADIO HARNESS
     Power Antenna          PINK          (+)          RADIO HARNESS
     LF Speaker (+)          WHITE/ BLUE
               THESE WIRES ALSO GO TO THE FRONT LEFT TWEETER
     LF Speaker (-)          BLACK/ BLUE
     RF Speaker (+)          WHITE/ RED
               THESE WIRES ALSO GO TO THE FRONT RIGHT TWEETER
     RF Speaker (-)          BLACK/ RED
     LR Speaker (+)          YELLOW/BLUE
     LR Speaker (-)          GRAY/BLUE
     RR Speaker (+)          YELLOW/RED
     RR Speaker (-)          GRAY/RED
     Steering Cntrls          OPTIONAL
     Speed Cntrl          NO
     Radio Security          YES
     Security
     Battery          YELLOW          (+)          IGNITION SWITCH HARNESS
     Ignition 1          WHITE          (+)          IGNITION SWITCH HARNESS
     Starter 1          ORANGE          (+)          IGNITION SWITCH HARNESS
     All Door Trigger
               USE EACH DOOR TRIGGER AND DIODE ISOLATE EACH WIRE
     Domelight Super          YELLOW          (-)          AT VEHICLE FUSEBOX
     LF Latch          YELLOW          (-)          AT MODULE UNDER DRIVER SIDE DASH
     RF Latch          GREEN          (-)          AT MODULE UNDER DRIVER SIDE DASH
     LR Latch          RED          (-)          AT MODULE UNDER DRIVER SIDE DASH
     RR Latch          BLACK          (-)          AT MODULE UNDER DRIVER SIDE DASH
     Trunk Trigger          WHITE          (-)          AT MODULE UNDER DRIVER SIDE DASH
     Hood Trigger          RED / WHITE          (-)          AT MODULE UNDER DRIVER SIDE DASH
     Alarm Disarm          GREEN/ RED          (-)          AT VEHICLE FUSEBOX
     Alarm Arm          GRAY/BLUE          (-)          AT VEHICLE FUSEBOX
     Parking Lights          YELLOW & BROWN          (+)          AT INTERIOR FUSE BOX HARNESS
               MUST USE BOTH WIRES AND DIODE ISOLATE EACH WIRE,
     Convenience
     Headlights-Lo          RED / BLACK & ORANGE          (+)          AT EACH HEADLIGHT
               CAN ALSO BE FOUND AT UNDER HOOD FUSE BOX, MAY ALSO BE RED / BLACK & BLUE ON SOME MODELS
     All Hazrd Lights          GREEN          (-)          AT MODULE UNDER DRIVER SIDE DASH
     Wipers-Lo          GREEN          (+)          AT VEHICLE FUSEBOX
     Wipers-Hi          BLUE          (+)          AT VEHICLE FUSEBOX
     Parking Brake          LIGHT GREEN          (-)          AT VEHICLE PARKING BRAKE SWITCH
     Remote Start
     Accessory 1          LIGHT GREEN          (+)          IGNITION SWITCH HARNESS
     Key Sense          RED / WHITE          (OPEN)          IGNITION SWITCH HARNESS
               THIS WIRE RESTS AT GROUND AND IS AN OPEN CIRCUIT WITH THE KEY INSERTED
     Tachometer          GREEN / WHITE          (AC)          AT INJECTOR #1
               ALSO AT ECM MODULE TO DRDIVER SIDE OF AIRCLEANER, PIN #2
     Speed Sense          WHITE/ BLUE          (AC)          IN HARNESS TO GAUGES
     Brake Lights          RED          (+)          AT SWITCH ABOVE BRAKE PEDAL
     Reverse Lights          WHITE          (+)          AT VEHICLE FUSEBOX
     Horn          GREEN          (-)          AT VEHICLE FUSEBOX
     Modules
     WIRE          LOCATION
     Please select another category
     Doorlocks/Windows
     Power Unlock          RED / YELLOW          (-)          IN HARNESS IN DRIVERS KICKPANEL
     PowerLock          WHITE/ BLACK          (-)          IN HARNESS IN DRIVERS KICKPANEL
     LF Window Up          VIOLET          (REV)          AT DRIVER WINDOW SWITCH
     LF Window Dn          ORANGE          (REV)          AT DRIVER WINDOW SWITCH
     RF Window Up          BLUE/WHITE          (REV)          IN HARNESS IN DRIVER KICKPANEL TO DOOR
     RF Window Dn          GREEN          (REV)          IN HARNESS IN DRIVER KICKPANEL TO DOOR
     LR Window Up          WHITE          (REV)          IN HARNESS IN DRIVER KICKPANEL TO DOOR
     LR Window Dn          BLUE          (REV)          IN HARNESS IN DRIVER KICKPANEL TO DOOR
     RR Window Up          GRAY          (REV)          IN HARNESS IN DRIVER KICKPANEL TO DOOR
     RR Window Dn          YELLOW          (REV)          IN HARNESS IN DRIVER KICKPANEL TO DOOR
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
