does the yellow starter wire needto be cu
rt4x4
Copper - Posts: 107
Posted: November 13, 2007 at 7:52 PM / IP Logged
when installing a dei 5900 does the yellow starter wire need to be cut in between the keyside and starter side of the remote start wires?
Platinum - Posts: 13,726
Posted: November 13, 2007 at 8:38 PM / IP Logged
I am not familiar with the DEI alarms, but I would assume that if you were installing the Starter kill function that yes you would have to cut the wire.
Twelvoltz
Platinum - Posts: 2,384
Posted: November 13, 2007 at 8:40 PM / IP Logged
There is some pretty significant information missing from this question: What is the Make/Model/Year of the vehicle?
The 5900 provides both a starter kill and anti-grind with the cut starter wire but with some vehicles adding a starter kill would require running the wires out under the hood.
rt4x4
Copper - Posts: 107
Posted: November 13, 2007 at 9:42 PM / IP Logged
it is a 2004 silverado
extreme1
Silver - Posts: 1,070
Posted: November 13, 2007 at 9:50 PM / IP Logged
you can as an added layer of protection, but since the truck has anitgrind built in, as well as passlock for antitheft, I normally don't do starter kill on these trucks, just tape off the green wire and hook up the purple to the trucks yellow wire
Shaughn Murley
Visions Electronics
Red Deer, Alberta
rt4x4
Copper - Posts: 107
Posted: November 13, 2007 at 9:55 PM / IP Logged
thank you for your help
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
