ultrastart in a mercury cougar
rob691
Member - Posts: 15
Posted: November 15, 2007 at 1:45 PM / IP Logged
Hi guys iam just in the process of fitting a ultrastart 1270 into my cougar one problem i have at the moment is the connection for the arm and dis arm it says the wire colours are BLACK/ green BLACK/ orange, but there are four of these in the alarm harness so i connected into what i thought was the right one but now i have noticed that my alarm light on the dash has gone out and i have no alarm or deadlocking allthough it locks and unlocks on the ford key ok.
KarTuneMan
Platinum - Posts: 7,056
Posted: November 15, 2007 at 7:42 PM / IP Logged
Did you test the wires before connecting them and doing possible permanent damage? Doesn't sound like it. You cannot make your connections based on what a diagram says is the color of the wire.
Another thing. Always post the year of your vehicle.....takes the guess work out!
rob691
Member - Posts: 15
Posted: November 16, 2007 at 1:30 AM / IP Logged
Hi kar tuneman, some how i blown two fuses one inside fuse box and one outside fuse box everything working ok now, by the way its a ford cougar year 2000 will try again tonight when i get in from work.
rob691
Member - Posts: 15
Posted: November 16, 2007 at 2:54 PM / IP Logged
right everthing working, well nearly i cannot programme the bypass unit  iam using a pku-f1 i have a perminent feed on the red wire but cant seem to get a negitive on the brown wire which is connected to violet/white wire on a ultrastart 1270 any idears thanks.
rob691
Member - Posts: 15
Posted: November 19, 2007 at 3:31 PM / IP Logged
anyone no the oe alarm colour's of the arm/disarm wiring in a 2000 cougar then.
KarTuneMan
Posted: November 19, 2007 at 4:25 PM / IP Logged
 FACTORY ARM BLACK/ blue In driver's kickpanel   -
 These wires will also lock and unlock the doors. These wires can also be found at the anti-theft module located behind the glove compartment.
 FACTORY DISARM BLACK/ white In driver's kickpanel   -
rob691
Member - Posts: 15
Posted: November 20, 2007 at 2:19 PM / IP Logged
cheers mate will try that tomorrow.
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
