problems command start, 92 wrangler
dan476
Member - Posts: 31
Posted: November 19, 2007 at 9:11 AM / IP Logged
Hey Guy maybe you can help me.
I am trying to install a command start PRO START CT-3260 on Jeep Wrangler 1992. It is a manual transmission, no power door/locks/windows/dome light.
I wired up everything except for green wire on the 6 pin plug. The green wire says - ((+) 5th Relay output (30 A) This high-current output can be used to power a second Ignition, Accessories or Crank wire.)
On the 5 pin plug I have everything wired up as per https://www.the12volt.com/installbay/alarmdetail/1233.html . I have Purple wire for the tach input going to the coil and hooked up to Yellow/Black again as per instructions.
Then I have 12 Pin Harness - on that one i have only parking brake wire installed. Not sure if there is anything else to be hooked up on that harness
Basically i can program the remote and i get feedback from it, I also I can go Into a Ready mode, I can start the car with the key, then pull the key out and it will stay running, then when i press 2nd button, engine will shut off. But i cannot start the car with the remote. What did I miss? I do not think car has any security to bypass, and the car starts without pressing clutch. There are #9 and #10 wires on 12 pin harness and I am not sure if they have to be connected, and where should they be connected.
Please Help.
Dan
~Dan
KarTuneMan
Platinum - Posts: 7,056
Posted: November 19, 2007 at 9:16 AM / IP Logged
I believe you need a door pin input to the R/S.
If it were an astrostart you were installing....I would know for sure this is the problem.
A Compustar guy will chime in here Im sure.
dan476
Member - Posts: 31
Posted: November 19, 2007 at 1:20 PM / IP Logged
hey guys, i thought i posted this but maybe i forgot to, but here are instructions to the pro start CT-3260
http://www.engines911.com/asdocs/CT-3260_ig_en_h370s380v155_040922.pdf
Thanks.
~Dan
moonliter
Copper - Posts: 322
Posted: November 19, 2007 at 9:50 PM / IP Logged
Definitely the door pin needs to connect to the rs. After the key is removed, the car stays running. RS needs to sense the door is open then close again. After it press button 2 to shut down, then the ready mode is complete.
dan476
Member - Posts: 31
Posted: November 19, 2007 at 10:40 PM / IP Logged
here's the thing
there is no door pin on the vehicle at all.
also right now as it stands I am bypassing my parking brake wire, I just ground it out to bypass. I cannot locate the wire for the brake. I just didn't see that wire, any idea where i should hook it up? the cheat sheet says its black with yellow line. But i did not see any black wires with yellow lines. I've seen some yellow with black line, and I tested it, but it wasn't it.
thanks
~Dan
KarTuneMan
Posted: November 19, 2007 at 10:50 PM / IP Logged
Carefull what you post up......your thread will be locked in a flash!
dan476
Member - Posts: 31
Posted: November 20, 2007 at 8:35 AM / IP Logged
umm what do you mean careful? I didn't break any rules have I? i just asked an honest question.
~Dan
dan476
Member - Posts: 31
Posted: November 20, 2007 at 8:42 AM / IP Logged
do i need to have "External trigger input" and "Ground out when running" wires hooked up?
~Dan
KarTuneMan
Posted: November 20, 2007 at 8:45 AM / IP Logged
No, and no.
dan476
Member - Posts: 31
sorry for another post but what should i do about lack of the door pins?
~Dan
