wiring diagram for aps 2?
bhodgins
Posted: November 29, 2007 at 4:57 PM / IP Logged
Are these still around? I have a Prestige APs-2 that I would like to add a relay and power lock actuator to, or if that is not possible, uninstall it completely and put in a newer system. Either way it would be helpful to have a Prestige schematic.
Thanks,
Brad
Chris Luongo
Platinum - Posts: 3,746
Posted: November 29, 2007 at 5:17 PM / IP Logged
Never heard of APS-2, about how old is it?
At any rate, most Audiovox systems should have a two-pin plug on the side of the brain. Shouldn't be hard to test which is lock and which is unlock.
the12volt
Administrator - Posts: 3,959
Posted: November 29, 2007 at 5:22 PM / IP Logged
The APS-2 is from the 90's. I'm fairly certain the wiring harness colors are the same as their current models. When I get a chance, I'll see if I have an old manual laying around.
wiring diagram for aps 2? -- posted image. the12volt • Support the12volt.com
tedmond
Gold - Posts: 4,610
Posted: November 29, 2007 at 5:42 PM / IP Logged
i got an old APS unit and the lock/unlock are negative which are 2 pin Green and Red
bhodgins
Posted: November 30, 2007 at 8:11 AM / IP Logged
yes I believe the APS is from between 1992 and 1995. The car is a 93 and I bought in 95 with the APS-2 installed. This has a single button remote, so I wanted to integrate a keyless entry system with it via a actuator and relay, as most other people with this car, I keep twisting keys in the lock due to a bad design.
tedmond
Gold - Posts: 4,610
Posted: November 30, 2007 at 2:22 PM / IP Logged
if u have a black control with one button lock/unlock and a green button next to it, all the modules during that times use the Red and Green wires. This system was installed in an Accord my sister owns and i removed htat for a new system.
bhodgins
Posted: December 04, 2007 at 10:59 AM / IP Logged
so will the red-green pins reverse voltage based on arm/disarm, or will I need the relay in between the alarm module and the power door actuator?
tedmond
Gold - Posts: 4,610
Posted: December 04, 2007 at 2:17 PM / IP Logged
you will need to use the 2 relays for actuators or reverse polarity, check door lock diagrams and it should show u
