561t, 06 fusion
hunter ele.
Posted: December 04, 2007 at 8:18 PM / IP Logged
can i use the 561t to add to RS to the factory keyless?
Twelvoltz
Platinum - Posts: 2,384
Posted: December 05, 2007 at 7:38 AM / IP Logged
If it is a Fusion then yes you can. The Ford remotes work when the remote start is running.
hunter ele.
Posted: December 07, 2007 at 5:25 PM / IP Logged
Hey all ,,,hey iv got a 06 fusion i put a 561t on,,, ,,and its not workin my instller said it was something to do with the positve  needing to be a negitive?    HELP
tedmond
Gold - Posts: 4,610
Posted: December 07, 2007 at 7:30 PM / IP Logged
? postive to be negative, polarity can be changed easitly with the use of a relay. is ur installer certified or knows what hes talkin about?
hunter ele.
Posted: December 08, 2007 at 7:47 AM / IP Logged
ya but whats happing is the pluse isnt stong enough to trigger the remote start
Twelvoltz
Posted: December 08, 2007 at 1:39 PM / IP Logged
I do the Ford setups using the factory remote quite often. I have NEVER had any that the pulse was not 'strong' enough in.
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
