jeep won't start
thejetmolina
Member - Posts: 22
Posted: February 18, 2009 at 2:58 PM / IP Logged
i have a 95 Jeep Grand Cherokee 4.0 6 Cylinder lots of lights, tvs, and sound systemalready did big 3. It won't start i will be getiing an H/O alt but i just want to get it running again.  The car runs once it is jump started and does not stall so the alt isnt bad it starts right away and shows 13 volts when running when jumped so i don't think its the starter but if i use a jumper pack showing 12.84 volts car wont start, the fan starts to turn but then just clicking. can anyone see a problem is it eletrical or is it fuel lines etc. any help is appreciated very much
Beep Beep who got the keys to the Jeep
Phreak480
Copper - Posts: 84
Posted: February 18, 2009 at 3:16 PM / IP Logged
surely an electrical issue, could be a bad battery, or even just bad connections.
ckeeler
Gold - Posts: 1,461
Posted: February 18, 2009 at 4:06 PM / IP Logged
bad battery. take it out and get it load tested (with it out of the vehicle).
ben_c_8
Member - Posts: 13
Posted: February 19, 2009 at 4:46 PM / IP Logged
ya i have a 99 jeep cherokee v8 theyre really sensitive to low voltage.. anything less then about 12.5 they wont run. also if your running a deep cycle/gel battery put a slow charge on it to recharge but ya i blew a cell in a normal battery, the alternators are farely strong though. try a blue or yellow top optima that cured my problems.
Ben carnes-2ma hk15x2 + 5500d
thejetmolina
Member - Posts: 22
Posted: February 19, 2009 at 8:19 PM / IP Logged
i should have mentioned i have an optima redtop i plan on getting a battery charger that i can keep plugged in over night
ckeeler
Gold - Posts: 1,461
Posted: February 20, 2009 at 12:45 AM / IP Logged
which will not help or do anything....but anyway.....
Posted: February 20, 2009 at 11:49 AM / IP Logged
Aren't these optimas deep cycle CK?  If so as you say throw it away and get the biggest meanest regular non deep cycle battery you can find that will still fit.  Used to use a type 068 600amp rate from a R/Royce in my Maximas, never any grief.
ckeeler
Gold - Posts: 1,461
Posted: February 20, 2009 at 6:53 PM / IP Logged
they are. but optimas dont do well with a "trickle charge". thats what i meant by my earlier comment.
thejetmolina
Member - Posts: 22
Posted: February 21, 2009 at 9:36 AM / IP Logged
would a high output starter help after i fully charge the optima?? what battery is recommended if optima is not doing its job
Posted: February 21, 2009 at 9:49 AM / IP Logged
See my comments above, just don't get a deep cycle battery, they're wonderful for lawn mowers.
