hard to turn ignition swith
supradude
Silver - Posts: 915
Posted: December 16, 2004 at 12:32 PM / IP Logged
Since it has got colder, I can't hardly get my switch to turn early in the morning. After I turn it the first time, it turns normal till the next day again. The last 2 days it was in the 20's and I had a real hard time turning it. Does anybody have any ideas on this problem? The car is a 85 Supra.
'85 Toy
auex
Platinum - Posts: 5,041
Posted: December 16, 2004 at 7:38 PM / IP Logged
WD40?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
supradude
Silver - Posts: 915
Posted: December 16, 2004 at 7:54 PM / IP Logged
Wouldn't WD40 or  3 - in -1  oil harm the electrical parts in the switch? I have thought about trying one of these, but I'm not sure if it would hurt something or not.
'85 Toy
auex
Posted: December 16, 2004 at 10:58 PM / IP Logged
Well I didn't say flood it but maybe. How about some white lithium grease, you should be able to find this at rat shack.
swamprat323
Gold - Posts: 1,335
Posted: December 18, 2004 at 11:25 AM / IP Logged
Pull it out and grease it. not hard to take out and taker apart. Your tumbelers are lock in by a cover so dotn worrire abotu that.
supradude
Silver - Posts: 915
Posted: December 18, 2004 at 7:16 PM / IP Logged
I'll try taking it out like you suggested, swamprat323. The worst thing is getting the steering wheel off. I'll have to get a puller. That might be all it needs.
'85 Toy
swamprat323
Gold - Posts: 1,335
Posted: December 18, 2004 at 10:47 PM / IP Logged
The wheel is the easy part, the key part coem out easy also, take the key clinder apart is bitch. if you cant get it apart, and after you get it out spary soem "penetrating gel lubricant with teflon"
