Walk through, Mazda B2200
hersheyloc
Copper - Posts: 86
Posted: December 22, 2004 at 5:10 PM / IP Logged
I have a Mazda B2200, and I want to make it a walkthrough from the cab, to the box with the canopy covering it. Basically, I have no idea where to start. I dont wanna just start hacking apart my cab, for obvious reasons. Does anyone have any good links or other forums that may help?
Hymer
Silver - Posts: 695
Posted: December 26, 2004 at 10:38 PM / IP Logged
Your gonna have to be mighty short.. Heh.. You'll have to box the frame a bit and before you start cutting, add some steel to renforce the roofline and the floor,, then build sort of a roll cage around the front of the box... p/u frames flex a ton but there isn't a ton of structure to the bodies themselves... Try to get a good plan together first...
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
auex
Platinum - Posts: 5,041
Posted: December 27, 2004 at 11:58 AM / IP Logged
Well, do you mean a "blow-through" or something to let the sound into the cab?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
hersheyloc
Copper - Posts: 86
Posted: December 27, 2004 at 11:29 PM / IP Logged
Ya something to let the sound through. I trashed the idea of making it a full walk through..there's no point. But ya, something to let the bass come in nice and clear.
jeffchilcott
Platinum - Posts: 2,483
Posted: January 06, 2005 at 1:17 AM / IP Logged
If your ruling out the walk through, Then just go with a full cap, remove the rear window, and seal the cap to the cab.   I have seen quite a few vehicles done like this I think it is probably thr easiest way to go
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Doyledee
Member - Posts: 14
Posted: January 09, 2005 at 8:41 PM / IP Logged
I (used) to have a truck with a walkthrough...  1988 nissan.  The camper cracked twice and then the cab cracked.... I partially rewelded the cab but without a roll cage....It still flexed.  I parked it.....  If I were to have one I would cut a square hole in the cab and use the accordian rubber boot..It is sold where they sell campers.. And I would get a flush bed cap.. Keep all the sound in as small an area you can for harder bass.....
97 Sebring Jx convertible
1500 RF amp with 2-10" Lanzar subs
2005 suzuki Katana 600
