escort heater relay
wolf56
Copper - Posts: 93
Posted: January 17, 2008 at 12:42 AM / IP Logged
well ive checked the fuses, but for some reason i have only 3 of my 4 fan speeds for the heater/ac, i can move it from spot 1/2/3/4 but 3/4 are the same speed, i spoke with a few ppl and they said it was a relay... idk if it is or not, but would it be expensive to have my mechanic replace? its been like this a year, and im positive it isnt a loose wire cuz then none of the fan speeds would work, and its not the switch either had that replaced already, so that leaves the relays...
tweak master
Member - Posts: 14
Posted: January 22, 2008 at 11:14 PM / IP Logged
Im not sure about ford but some chevy and dodge blower motor setups have resistor packs to limit current to the blower motor to regulate speed, usually found in the duct by the blower motor (for cooling purposes). If three and four are both high speed (if theres a BIG difference between speed two and three/four) then I would suspect a shorted resistor on speed three.
wolf56
Copper - Posts: 93
Posted: January 22, 2008 at 11:51 PM / IP Logged
idk really, it was like 4 wasnt there, it was normal from 1/2/3 but 4/3 where the same, but i just sold that car and have a 97 vw golf trek now, so if a admin/mod could close this?
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
