wiring actuated license plate
hallperson
Member - Posts: 7
Posted: May 17, 2008 at 3:23 PM / IP Logged
hey guys,
i made a topic about a year back trying to wire my actuated license plate up. but know a year later finally gettin to put it in. i was tryin to find out how to wire it so that when the truck comes on it will go down and when the truck is turned off it will go up. but the motor does not have limiting switches to stop it. you have to hold the switch down until it shows completely. then the same to hide it away. but i want it all to be stand alone so i dont have to touch it. the motor has only 2 wires coming off of it and the switch just reverses polarity.
any help would be great   thanks
hotwaterwizard
Silver - Posts: 1,350
Posted: May 17, 2008 at 7:05 PM / IP Logged
wiring actuated license plate -- posted image.
Al you need now is a way to cut power when up and down.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
hallperson
Member - Posts: 7
Posted: May 18, 2008 at 8:44 AM / IP Logged
is it possible to make a time controlled circuit like it would run for 5 seconds or so     thanks alot joe
hotwaterwizard
Posted: May 18, 2008 at 7:55 PM / IP Logged
You can change the timing by changing the capacitor.
47uF = 3 sec
100uF = 10 sec
220uF = 15 sec
470uF = 30 sec
1000uF = 1min
Stockton California
