need source 2 coil latching relay
noctorum
Member - Posts: 17
Posted: July 02, 2008 at 10:45 PM / IP Logged
Havn't been able to find an online supply for double coil latching relays rated to 12v30a, any good sites to check?
Platinum - Posts: 12,488
Posted: July 03, 2008 at 9:20 AM / IP Logged
What application are you using this in ? Just curious.
KPierson
Platinum - Posts: 3,527
Posted: July 03, 2008 at 9:43 AM / IP Logged
You could possibly use a latching relay with a smaller contact rating and drive a 30A automotive relay.
Kevin Pierson
tekstyle
Member - Posts: 13
Posted: July 24, 2008 at 11:33 PM / IP Logged
i found this.
http://www.alliedelec.com/Search/ProductDetail.aspx?DESC=G4W-1114P-US-TV8HPDC12&ID=&SEARCH=&SKU=821-0725
http://www.alliedelec.com/Images/Products/Datasheets/BM/MAGNECRAFT/MAGNECRAFT_8500509.PDF
12VDC, 15A, impulse relay. maybe this will help you. i just cant figure out what the pins mean
Platinum - Posts: 13,726
Posted: July 25, 2008 at 1:44 AM / IP Logged
http://www.alliedelec.com/Search/ProductDetail.aspx?SKU=850-0506&MPN=755XBXCD-12D&R=850-0506&SEARCH=850-0506&DESC=755XBXCD-12D?utm_source=Allied&utm_medium=merchandising&utm_campaign=Allied_Top_Sellers&utm_content=850-0506
Above is  a dual coil DPDT latching relay rated at 16 amps.  You can parallel the 2 sets of contacts to give you 30 amps of current capacity.  Below is the same relay with a different type of connection method on the bottom of the relay.
http://www.alliedelec.com/Search/ProductDetail.aspx?SKU=8500586&MPN=785XBXCD-12D&R=8500586&SEARCH=8500586&DESC=785XBXCD-12D
