delayed turn on relay
tj.poorman
Member - Posts: 21
Posted: May 27, 2009 at 4:06 AM / IP Logged
delayed turn on relay -- posted image.
I have a Pioneer in-dash dvd player that has to not "see" ground then "see" it in order to play movies. My question is if I have the relay set up correctly and also what size capacitor I would need to acheive a 5 and 10 second delay.
Thanks,
KPierson
Platinum - Posts: 3,527
Posted: May 27, 2009 at 7:06 AM / IP Logged
Bypassing the safeties isn't a subject that is typically discussed around here.
Kevin Pierson
tj.poorman
Member - Posts: 21
Posted: May 27, 2009 at 9:57 PM / IP Logged
The DVD player is installed in a show vehicle, I'm bypassing the safety so I don't have to sit there and flip a switch everytime the vehicle is turned on.
tj.poorman
Member - Posts: 21
Posted: May 31, 2009 at 6:00 AM / IP Logged
I dont care about the safety part. My main concern is getting the right size capacitor to change the delay time.
Posted: May 31, 2009 at 11:43 AM / IP Logged
So connect the parking brake wire directly to ground, everyone does that here anyway, with the owner's signed agreement.
tj.poorman
Member - Posts: 21
Posted: May 31, 2009 at 6:55 PM / IP Logged
I can't... the player has to not "see" ground then "see" it before it will play. Simply grounding the wire will not work.
