saab auto roof
russell31
Member - Posts: 13
Posted: April 21, 2012 at 6:13 AM / IP Logged
Is it possible tor have the Saab switch to stay energised until the roof is either up or down. It's a 2000 Saab so the roof needs to be UNLATCHED at th front first but I don't want to keep hold of the switch either way. I want the roof working by its self as I'm either pulling in or out my driveway. Was thinking of a window relay as I have a Clifford one and a cobra one. No wiring diagrams for either tho. I'm very useful with cars a d electrics so not fazed by trying anything. Thanx in advance.
Posted: April 21, 2012 at 8:30 AM / IP Logged
Use a DEI 528t timer relay off the switch.
Set it for the time it takes plus 2 seconds.
A window relay won't do it, too short on the time, too much on the load and you probably have more than 1 motor.
Cobra window motor? Must be a museum piece.
russell31
Member - Posts: 13
Posted: April 21, 2012 at 8:48 AM / IP Logged
Hi. Thanx for that I've been thinking 528t but where would I wire it in the system. The roof has an electric tonnue but hydraulic roof pump so needs to be on the switch really. Will I be able to wire it just after the switch so basically the switch acts as one touch. Obviously I would need two of them for up and down?
Posted: April 21, 2012 at 8:57 AM / IP Logged
Yes I meant at the switch. For each direction depending on whether the switch has three or five terminals, ONE wire will change state for either direction, from open circuit to either NEG or POS, it doesn't matter which that's the wire.
And yes to another for the other direction.
russell31
Member - Posts: 13
Posted: April 21, 2012 at 9:22 AM / IP Logged
Ok. Not sure where I can find a wiring diagram for the switch pack.
Posted: April 21, 2012 at 9:32 AM / IP Logged
Wiring diagram? TEST
It will only be 2 types, a 4 or5 wire wired as a window switch powering the motors directly or a SPCO type,3 terminals either POS or NEG input (usually the latter) feeding relays. It doesn't matter you just have to find one wire which changes stater for each direction. Couldn't be more easy.
russell31
Member - Posts: 13
Posted: April 21, 2012 at 9:45 AM / IP Logged
Where's the best place to buy a 528t.
Platinum - Posts: 7,828
Posted: April 21, 2012 at 10:36 AM / IP Logged
Recently got 3 of them from "FleaBay" for $11 each...   N.I.B.   saab auto roof -- posted image.
Posted: April 21, 2012 at 10:47 AM / IP Logged
Good thinking, there's none in the UK at the moment.
Officially a car alarm shop.
russell31
Member - Posts: 13
Posted: April 21, 2012 at 10:55 AM / IP Logged
Mega money I expect tho.
