If you wish to post a reply to this topic, you must first login.
If you are not already registered, you must first register.
Thursday, May 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
It allows me to turn the psu off with the remote out of my radio, (Which actually only requires one relay) but it doesn't turn it back on. I don't have many parts, just random capacitors and relays and such. Any help will be appreciated.
By the way, both the normally open and normally closed contacts on the relay are both grounded, with the idea being that the switching from one ground to another would trip the psu back on. I don't think it's a problem with it switching back to N.O. when the psu tries to turn back on, as it has to switch to N.O. when it's first turned on by the remote line. I think it's just not disconnecting the 3v and ground long enough.
