Diagram for 2 Devices with 1 Switch
wiker man
Member - Posts: 6
Posted: April 23, 2015 at 6:46 AM / IP Logged
Hi, I need some help with this simple thing I am trying to do but too worked up to figure out myself. I am going to be using a simple on off switch, 12V. When on, it will complete a circuit / provide 12V to a device which will activate. But at the same time I am wanting to hook another device to it, which as soon as its pressed on will turn off.
So when Switch is On. #1 Device is On and #2 Device is Off, and when Switch is off, I want #1 Device to Turn off while #2 Device turns on.
Diagram for 2 Devices with 1 Switch -- posted image.
Posted: April 23, 2015 at 10:45 AM / IP Logged
Power to each then use a SPCO (Single Pole Change Over) switch to switch the ground side.
wiker man
Member - Posts: 6
Posted: April 23, 2015 at 3:57 PM / IP Logged
will you draw me a diagram please ? and can it be done with relays?
wiker man
Member - Posts: 6
Posted: April 23, 2015 at 3:58 PM / IP Logged
I actually have a spesific on off switch which is on/off only, not SPCO and I rather use that. thanks.
the12volt
Administrator - Posts: 3,957
Posted: April 23, 2015 at 4:48 PM / IP Logged
One side of switch to ground.
Other side of switch to terminal 86 of an SPDT relay.
Fused 12V+ to terminals 85 and 30 of SPDT relay.
Terminal 87 of SPDT relay to device 1 power.
Terminal 87a of SPDT relay to device 2 power.
Both device grounds to ground.
Diagram for 2 Devices with 1 Switch -- posted image. the12volt • Support the12volt.com
hotwaterwizard
Silver - Posts: 1,350
Posted: April 25, 2015 at 10:38 PM / IP Logged
Here you go!Diagram for 2 Devices with 1 Switch -- posted image.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
Posted: April 26, 2015 at 4:18 AM / IP Logged
Cynical me would like to question both of the above answers in light of the fact that we didn't inquire the purpose of the circuit, is it in an auto and therefore will one circuit be on all of the time? That's why I recommended a centre off switch.
hotwaterwizard
Posted: April 26, 2015 at 8:20 PM / IP Logged
True we don't know the application. I read the post several times to come up with this solution.
Stockton California
Posted: April 27, 2015 at 3:07 AM / IP Logged
Yes, let's hope the 12V+ source is ignition switched.
hotwaterwizard
Posted: April 27, 2015 at 9:24 PM / IP Logged
switched and fused.
Stockton California
