tracker headlight relay
michaelmrc
Member - Posts: 21
Posted: May 15, 2015 at 10:37 PM / IP Logged Link to Post Post Reply Quote michaelmrc
hi all i have a 2003 tracker im installing some off road lights on. i was wanting to tap into the high beam light wire with a relay and control the lights this way. i noticed that all the wires to the lights are red RED / white or WHITE/ red i found one that appeared to be high beam connected the relay in standard fashion hit the high beams works great turns off on low beam but if i turn off the headlights the driving lights come back on. im thinking that this must have something to do with the daytime running lights. any suggestions on how to make this work. thanks
davevancat
Posted: November 08, 2015 at 10:44 AM / IP Logged Link to Post Post Reply Quote davevancat
anyone have any suggestions to this question? i have an 02 tracker i was wanting to install a light bar on the bush bumper. would like to wire it into the high beam switch as well but not sure of the procedure.thanks
