DPDT relays?
OwenZ
Member - Posts: 44
Posted: May 27, 2003 at 5:49 PM / IP Logged
Hi,
Is there any way I can wire up two SPDT relays to form one DPDT? I looked through the guides and special applications but didn't really see anything, course I'm a novice, I probably passed right over it.
I wanna do something like this,
http://www.autospeed.com/cms/article.html?&A=0059&P=1
but with SPDTs if possible.
Thanks,
Owen
TomEllis
Copper - Posts: 52
Posted: May 28, 2003 at 12:09 PM / IP Logged
Yes you can.
wire the coils of the two relays in parallel. Use one for the top contacts and the second for the bottom contacts of the DPDT relay.
Good luck,
Tom
DPDT relays? -- posted image.
OwenZ
Member - Posts: 44
Posted: May 28, 2003 at 12:17 PM / IP Logged
Thanks! It still isn't "clicking" tho...I should have negative stars next to my name!
Could you tell me in more detailed terms where to connect what?
Thanks,
Owen
xetmes
Silver - Posts: 586
Posted: May 28, 2003 at 2:12 PM / IP Logged
xetmes
Silver - Posts: 586
Posted: May 28, 2003 at 2:13 PM / IP Logged
oops that should be together = DPDT
OwenZ
Member - Posts: 44
Posted: May 28, 2003 at 3:00 PM / IP Logged
Cool! Thanks!
Owen
