Momentary Ground - Positive Output
ewingr
Copper - Posts: 60
Posted: June 09, 2017 at 12:16 PM / IP Logged Link to Post Post Reply Quote ewingr
I had to ask such a simple question, but I went over to the diagrams to look, but I guess I'm not familiar with the terminology enough to be sure any of those are what I want to accomplish.
I simply want to press a button that will supply a ground to a relay which will then trigger the relay to send positive out to a trunk solenoid.
I really would appreciate it if someone could tell me the correct wiring plan for a relay to accomplish this.
Thanks...
Roger
ewingr
Copper - Posts: 60
Posted: June 09, 2017 at 12:22 PM / IP Logged Link to Post Post Reply Quote ewingr
I did some more searching, and I think the one on the left at This page will do the job.
I'll keep an eye here in case someone tells me that is wrong.
Roger
wirewise
Moderator - Posts: 489
Posted: June 10, 2017 at 12:17 PM / IP Logged Link to Post Post Reply Quote wirewise
That's the one you want to use.
~wirewise~ Verify all wiring with your meter before making any connections!
ewingr
Copper - Posts: 60
Posted: June 10, 2017 at 2:21 PM / IP Logged Link to Post Post Reply Quote ewingr
Thank you...
Roger
