If you wish to post a reply to this topic, you must first login.
If you are not already registered, you must first register.
Thursday, April 30, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
Hmmm, here's a few conflicting diagrams (not sure which is correct). Either way one side of the coil should have 12 volts with the key on.
I helped a friend once with a similar issue. I wired a relay under the dash that provided power to the coil with the key on. A toggle switch went to ground on the other side of the coil. When she flipped the switch with the key on, power was sent to the a/c compressor clutch.
I just told her to cycle it off for a minute or so after running a few.
