Ground interrupt
hillbilly71
Posted: May 18, 2004 at 10:28 PM / IP Logged
I am looking to momentarily  interrupt a ground wire by using a relay with a ground input. It doesn't have to have a ground input to the relay but it would make it easier.
bxscig
Copper - Posts: 41
Posted: May 19, 2004 at 1:21 PM / IP Logged
Use a relay and connect the ground u want to disconnect to that relay's NC pin and then trigger the relay pin 85 with the ground while 86 is +12Vs.  pin 30 would be the ground u want it connected to.  that will break it as long as the relay is activated.
Wednesday, April 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
