Relay wiring for two windows
red a9x
Posted: May 21, 2004 at 8:18 PM / IP Logged
Hello everyone... I'm new to this forum. I have been told I need to wire in relays to my power windows I installed in my car. I just haven't used any relays before - so I need to know how to wire it up using the common 5 pin relays...
I have two 6 pin rocker switches (power + & - into middle pins and outputting power at either end of switch) and the 12v motors just have the two wires. (the switches are momentary ones - so I'll just hold them down when using the window). Any help appreciated - I need a diagram if possible because I'm not familiar with the terminal names!
cyborg666
Member - Posts: 9
Posted: May 25, 2004 at 1:46 PM / IP Logged
Here is a diagram for one motor with one switch, just copy it for the other motor and switch.
Relay wiring for two windows -- posted image.
red a9x
Posted: May 25, 2004 at 3:48 PM / IP Logged
Thanks heaps for that cyborg666 Relay wiring for two windows -- posted image. now all I have to do is wire the rest of my car up!
the12volt
Administrator - Posts: 3,959
Posted: May 25, 2004 at 4:40 PM / IP Logged
You only need two relays to control each window motor with each switch. It will also be easier to add window modules, if you decide to in the future, with this configuration by having each leg of each window motor resting at ground.
Relay wiring for two windows -- posted image. the12volt • Support the12volt.com
red a9x
Posted: May 26, 2004 at 1:05 AM / IP Logged
Thankyou for that too....
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
