Can I use 1amp diod?
Md_ru
Member - Posts: 6
Posted: October 11, 2002 at 11:55 AM / IP Logged
Hi guys, I'm putting together a starter kill module. I never could buy a kit from a local autostore. So I'm using 30amp (12V) relay. There's a diod between 86 and 85 pins. Is this 1 amp diod or not? If it's I guess I can buy it from Radioshack. Appreciate your help.
https://www.the12volt.com/relays/page2.asp This is the diagram , Is that 1amp diod? Thanks
djfearny2
Silver - Posts: 810
Posted: October 11, 2002 at 6:02 PM / IP Logged
listen most of the time you dont need a diode its only those weired alarms so what you can do is try it right away now another way to hook up the relay is this
pin 85 output negative of alarm
pin 87a and pin 86 tap together that is the key side of starter kill
pin 30 output to motor side of starter wire do it like this if you dont want to use the diode and this way there is now way to get feedback in the alarm because the starter wire only shows possitive when you go to start the car.
Jon
Installer/Help Technician
---coral springs florida---
Md_ru
Member - Posts: 6
Posted: October 12, 2002 at 9:46 PM / IP Logged
Thanks!  I though got pack of diodes and put together as on the picture. It works fine.
