Dome supervision on Arm/Disarm
davidachew
Member - Posts: 31
Posted: July 18, 2005 at 3:43 PM / IP Logged
Ok here is the deal, Ive got a 05 f250 I bought a keyless entry alarm sys on e-bay, it's installed and everything is working except the interior lights when I arm or disarm it. I put meter on the wire and I get a ground but no pulses when system is armed or disarmed. i guess something is wrong with system (guess thats why i got it for such a good price). Here is my question, can I hook it up so the dome lights come on when the doors are unlocked and off when the doors are locked? Any help would be greatly appreciated.
genehewett
Copper - Posts: 151
Posted: September 14, 2005 at 8:47 PM / IP Logged
Need more info like system brand. Most systems work like this. The dome light output is low current so you need a relay. You need a relay anyway because the dome light trigger is positive. The output from most systems should have ground only after disarm for a preset amount of time. Connect most systems like this.
#85 to domelight output from system, #86 and #30 to fused high current source, #87 to domelight trigger wire in vehicle. Always test wires with DVOM first! Good luck.
Dome Supervision BLACK/ lt. blue  +  pass kick or cluster, blu plg, pin26
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
