pwr door lock relay problem?
azcat
Posted: January 19, 2006 at 10:01 PM / IP Logged
I hooked up my actuator and relays as directed by the “Actuators / Reverse Polarity” part of the site. The relay won’t click and it immediately blows the inline 20a fuse when I reconnect the battery. If I remove the ground from 87a and replace the fuse I can hear the relay work/click and the fuse doesn’t blow. But right when I reconnect the ground it blows. I’m not new to this and all my other relays work flawlessly. What could be the problem?
THANKS,
Joe
pwr door lock relay problem? -- posted image.
azcat
Posted: January 19, 2006 at 10:33 PM / IP Logged
BTW, not that it matters much but it’s for a 1967 Mercury Cougar…. so I’m running my own new wiring. I just can’t figure out why the ground blows the fuse when it works fine with the ground disconnected. Makes no sense to me. I have been looking over my work over and over again and I just don’t see any reason for my problem.
Thanks again,
Joe
