relay system using momentary switches
eeuler35thss
Member - Posts: 8
Posted: August 09, 2006 at 7:43 PM / IP Logged
i need a to make a relay system using momentary switches.  i would like to to where i have lets say 5 switches and when i press one in it turns on and stays on, but if i press another one of those switches i want the first switch system to turn off and that second one to turn on.  how would i go about doing this.  can someone draw me up a diagram so that this will work.
thanks in advance.
eeuler35thss
Member - Posts: 8
Posted: August 13, 2006 at 12:18 PM / IP Logged
anyone know how to do this without relays?  i just want to finish my project.
KPierson
Platinum - Posts: 3,527
Posted: August 14, 2006 at 9:56 AM / IP Logged
What kind of project is it?
It could be done fairly easily with a microcontroller, but doing it with relays alone would require a lot of relays and wouldn't be practical for a car.
Kevin Pierson
eeuler35thss
Member - Posts: 8
Posted: August 14, 2006 at 12:59 PM / IP Logged
its for a display thats going to be able to move easily for shows.
hotwaterwizard
Silver - Posts: 1,350
Posted: August 19, 2006 at 9:58 PM / IP Logged
You could just use a cam switch. Or interlocking push switches.
http://www.sphere.bc.ca/test/tek-parts/tekparts9.html
relay system using momentary switches -- posted image.relay system using momentary switches -- posted image.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
eeuler35thss
Member - Posts: 8
Posted: August 20, 2006 at 8:47 PM / IP Logged
i thought about those but seems like the biggest they can go are 5 switches.
is this true?
KPierson
Posted: August 20, 2006 at 9:20 PM / IP Logged
How many are you looking to do?
Kevin Pierson
hotwaterwizard
Posted: August 20, 2006 at 11:09 PM / IP Logged
Sure they do.
Finding a supplier? Well that is another issue.
http://www.wescospec.com/products-components.htm
http://www.ceiecz.com/a12.php3?cpid=2393&cpxlmc=&cpxlbh=003001005&no=&page=
Stockton California
eeuler35thss
Member - Posts: 8
Posted: August 22, 2006 at 1:48 AM / IP Logged
thanks.  thats not really the rounte i wanted to go for because i wanted all the buttons to be next to each radio and speaker setup, but this seems to be the only way i can find to do it.  i know that it can be done but not sure if there is a control unit or something to make it work how i sorta pictured in my head.
KPierson
Posted: August 22, 2006 at 8:16 AM / IP Logged
How many differeing switches do you want?
Kevin Pierson
