Wiring my electric water pump
oneslowz28
Posted: September 09, 2006 at 4:43 AM / IP Logged
Hello. Im new and am having some trouble wiring my electric waterpump up with a relay, led, and toggel switch. What im wanting to do is be able to cut my electric water pump on with a toggel switch and have a led come on letting me know that the water pump is on. The reason i want to use a relay is that the water pump draws 8 amps and I feel that that may be alot on a 2 buck toggel switch. Can someone please explain or draw a diagram on how to wire this up and what relay to use? I have tried but cant seem to get it to work. I tried just straight wiring it through the switch and then the led inline and it worked but with the resistor on the led it was limiting the power going to the pump to 4.8 volts and the pump was barely turning over. Any help will be greatly appreciated.
oneslowz28
Posted: September 09, 2006 at 4:45 AM / IP Logged
I forgot to add that the water pump has a power wire and a ground that just grounds to the body ground.
hotwaterwizard
Silver - Posts: 1,350
Posted: September 10, 2006 at 7:33 PM / IP Logged
Here you Go!
Wiring my electric water pump -- posted image.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
oneslowz28
Posted: September 13, 2006 at 12:20 AM / IP Logged
thanks
Monday, April 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
