smart starter kill relay 2005 pathfinder
nsgguy
Member - Posts: 7
Posted: December 15, 2006 at 2:34 PM / IP Logged
need help with this one!! how do i wire this relay for the starter kill on a 2005 nissan pathfinder??
installation sheet says: relay must be diarmed BEFORE ignition switch is turned on, may trigger check engine light, reset by cycling key on/off. aux. power can be connected to any fuse that has power when the ignition is in the off position. part number 6408A
any info is greatly appreciated
Thank you all
Big Dog
Gold - Posts: 1,265
Posted: December 15, 2006 at 2:56 PM / IP Logged
Go to your underhood fusebox on the passenger side.
Locate the start relay. Replace it with the 6408A.
Find a fuse in the same fuse box (any amperage), using a probe or test light, which has 12V pos with the key turned off and the engine not running. Remove that fuse and replace it with the wire with the two prong connector of the 6408A. Put the fuse you removed into the inline fuse holder  between the 6408A and the two prong connector.
Program your transmitter as per the instructions which came with the Smart Relay.
Prepare your future. It wasn't the lack of stones that killed the stone age.
nsgguy
Member - Posts: 7
Posted: December 16, 2006 at 8:56 AM / IP Logged
thank you
where can i get a 6408a relay
thanks again
Thank you all
