How about a search?
csorrows
Member - Posts: 9
Posted: July 08, 2003 at 3:38 PM / IP Logged
When you do a search in the installer database for an entire state (search blank but select state and country from pull down menus) you get the whole country!How about a search? -- posted image. It seams to me the code should give all the results for a state if selected in the pull down but it ignores it.How about a search? -- posted image.
You can build anything if you have enough time and patience!
the12volt
Administrator - Posts: 3,959
Posted: July 08, 2003 at 3:54 PM / IP Logged
If you select a country, you will get all results from the chosen country as well as the selected state. Try just selecting the state and leaving everything else blank.  Here's a search just for Texas: https://www.the12volt.com/installbay/findinstaller.asp?search=yes&City=&state=Texas&country=&Submit=Search
How about a search? -- posted image. the12volt • Support the12volt.com
csorrows
Member - Posts: 9
Posted: July 10, 2003 at 1:56 AM / IP Logged
Well that would make to much sense I guess. *thinks of getting more sleep* Nah, too much to do to sleep. Anyways, Thanks!
Dm4ca
Member - Posts: 12
Posted: July 15, 2003 at 9:14 AM / IP Logged
I'm looking for a particular product in the Buy/Sell forum. I get EVERY mention of the product on all forums with no indication what forum the post was in, so I have to read them all.
The Search function here is seriously weak!
the12volt
Posted: July 15, 2003 at 9:26 AM / IP Logged
If you are looking for a particular product in the Buy and Sell forum, you can limit your search just to that forum in the drop down menu provided here: https://www.the12volt.com/installbay/search_form.asp . If you are only searching from this page, then your results will include all forums.
Dm4ca
Member - Posts: 12
Posted: July 15, 2003 at 9:34 AM / IP Logged
Okay, how do I get to
via
https://www.the12volt.com/installbay/search.asp
the12volt
Posted: July 15, 2003 at 9:43 AM / IP Logged
How are your getting to https://www.the12volt.com/installbay/search.asp ? The link to https://www.the12volt.com/installbay/search_form.asp is at the top of each forum page.
the12volt
Posted: July 15, 2003 at 9:45 AM / IP Logged
cpgoose
Gold - Posts: 1,098
Posted: July 15, 2003 at 10:49 AM / IP Logged
How about a search? -- posted image. Good job 12volt, keep up the good work! How about a search? -- posted image.
Q: What's the best nation in the world?
A: Donation!     Donate to the12volt.com
the12volt
Posted: July 16, 2003 at 7:51 AM / IP Logged
Thanks cpgoose ;)
